Adjusting for larger rear tires?
Old 10-20-2010, 10:19 AM
STEWARDORNG's Avatar
Question Adjusting for larger rear tires?
Has anyone been able to adjust for larger rear tires so the ABS,Brake lights don't come on. I want to run some drag radials that are only availabel in larger sizes? Thanks!
I have a 2002 Formula LS1 A4
Old 10-20-2010, 11:13 AM
bigj2717's Avatar
The ABS light will only come on if there is a 2 or more inch difference in tire height. The ABS is something you can not adjust with a tune you usually live with the light or remove the bulb
Old 10-20-2010, 01:09 PM
Thanks!
