335/30/18 on these wheels in the back... will it fit?
I'm wondering if these wheels in the back (18x10.5)
http://www.oewheelsllc.com/Wheels-fo...viewsTabAnchor
will these fit a 335/30/18 tire? Will they rub? Will I have to beat the wheel well out (BFH mod)? If so, does it take a LOT of beating?
any info/ideas are appreciated! I've got 305/35/17's on there now and they dont rub.
edit: oh this is on a 94 Firebird Formula on stock rear ride height.
got a pic of what your BFH'ing looks like? I suspected I'd have to do something like that, just trying to figure if it's worth it... if the extra 30mm actually helps with traction that much.
I have been looking lately and come up with quite a few cars on here running a 335/30/18. I don't know about how much you will have to beat it in, but I will say that is my new tire size when I get my rear setup, then a 285/30/18 on the front. It should look pretty beefy when I'm done.
Check out this link for some pics and tire size specs, lots of pages too
https://ls1tech.com/forums/wheels-ti...uote-pics.html
All these people running that tire on this site are running the Nitto 335's...which arent a true 335. More like a 315. Nitto DRs run narrow compared to other brands. So they should fit fine. If you are looking at other brands there are a couple people running 335/35/17 Hoosiers... so true 335s will fit although Im sure it took a little work.
To fit a 335/30/18 its going to take a little BFHing to the inner wheel wells I'm sure and you will probably need to roll your fender lips. And adjustable PHB is deffinately required to, or a watts link
I'm planning on running 285/35s up front and 335/30/18s out back when I can find some rims to fit my junk, but narrowing my rear axle has turned into a nightmare and wheels are probably going to cost me my first born son haha only kidding. Check out the link I posted above, there are quite a few guys running the 335s and they look amazing on these cars IMO
A 335 should not go on a 10.5" wheel....regardless of the brand. A 315 is the largest you should run on that tire. It's no different then running a 315 on a 9.5" wheel; it's not safe.
