How do I make these fit?
285/40/17 on the front
335/35/17 to go on rear.
I bought new rims and these are the tires already mounted with good tread. Am I going to have a problem and need to do major modifications? Help would be great guys, thanks.
Edit: This is a 98 Z28 Camaro, Stock Suspension, Stock Height.
Bolt the rear wheel and tires on with the suspension loaded (Jack and jackstands under the rear end housing, not the chassis) and look to see where they're rubbing. Remove and pound that area with a huge hammer, and re check clearance. Repeat until enough clearance has been gained. Doesn't mess anything up, nothing from inside the wheel well can be seen from the outside of the vehicle.
