28-12.50-15
28-12.50-15
just got 2 rear mickey thompson ET street drag radials from my buddy. i can not seem to find a shank style lug nut to fit. read alot of FAQ on here and havent found any.
here is them just mounted up-
http://picasaweb.google.com/lh/photo...eat=directlink
i got some. there about an inch they dont thread as far on the stud as i'd like them too though. but the rims is rubbing the caliber so we cant even get the 5 nut in.
Studs you should use:
http://www.summitracing.com/parts/ARP-100-7713/
Lugs you should use:
http://www.summitracing.com/parts/WLD-601-1422/
For Weld Draglites, you will need to grind the rear calipars down to clear the brakes. Many have done it, it's not a huge issue, just time consuming. Lots of putting the wheel on, looking for clearance, removing, grinding, repeat. I've found it easiest to grab some black spray paint, put the wheel on loose, spin it, check to see where the wet paint rubbed off, grind there, and repeat. You really need to run a ARP 3" stud with those Weld wheels (Part # ARP-100-7713) if I remember correctly, and the open end Weld 1.380" shank lug nuts.
hey i found these studs. they come in a pack of 5 instead of 4 and about 20 dollars cheaper each set. BUT there 3.25in in length not 3.5in. this would save a bunch of money
http://store.jandjspeedshop.com/arp-...tei-p-289.html
also same thing. i found these on summit, there a set of 5. so now i wouldnt have to buy 3 sets just two and have left over ones. but the only thing about these are the length.
http://www.summitracing.com/parts/WL...1452/?rtype=10
I ued 7708's on my draglites on my old z28 and the lugnuts threaded pretty far onto them but the stud didn't come all the way through the nuts. I would just order the 7713 studs they are 3/4" longer I think
