Will these fit?
Will these fit?
Need to buy new wheels found a set of 15" weld prostarts with 5.5" of backspacing. These were on a third gen Camaro. Will they work with my fourth gen TA? Also to put these on do I just have to grind down the calipers in the front and rear or just the front?
I think you will only have to grind on the front calipers for clearance. the rears should clear no problem.. How wide are your rear wheels.. I have 19 x 11s on the rear orf my trans am.... i thinks a 10 inch wide wheel with 5.5 back spacing is a common offset and should fit.. I think i would talk the guy with the wheels and see if u can test fit.. to see if they clear... usually the guys dont mind as long as your buying the wheels in the end... hope this helps
