Got ABS INOP light 2 days after getting rear tires...related?
If you changed the size of your tires then yes thats what caused it. On my old Camaro I upgraded the stock 16s to 17&18 C5 Z06 wheels. With different diameter tires on it caused the ABOS and Brake Light to always be on. Had to tune it for different sizes for it to go away.
I dont think it does any harm, Im not really sure. I did drive with it for probably a year before the car was tuned though. The only thing I could think of is it might screw with the ABS if you were to slam on the brakes but I honestly wouldnt worry, I was fine with it for awhile.
Yeah be careful, it can mess with your brakes. I used to have this problem when I was running a "28 tire on my trans am. Just pull the ABS fuse so the brakes will respond normally. Be aware of course that you will not have ABS but you don't have ABS when the light is on anyways.
As far as your ABS light being on, mine's been that way for years due to taller rear tires, and has not had any negative effect on my car.
