17x11 wheel questions
i have a pair of 17x11 wheels with a 50mm offset. how will these fit my 98 ss? also what size tire is recommended for these wheels on this car??
The 50MM offset will work. You'll have to have the rearend supported when taking the wheels off and on. If it's on a lift and the rear end is hanging then you'll run into or get hung up on the bump stops. You'll also want to make sure you're rearend is square with a panhard bar if you're lowered.
1 Post
^ There's a thread where someone was asking about cutting the bump stops off and they were telling the OP no cause it made the car ride like **** or something like that. IDK I've never had a reason to cut off my bump stops to know.
