Lets see your high end wheels.
#301
I am going to change up the splitter a little. The winglettes don't look bad, but I think I can do better. I needed a splitter that actually works. So this is actually attached to the bumper mount and made of a plastic aluminum laminate. It also meant converting to a front breather.
Shoot me an email if want any input.
Getting to 168mph on this track.
#303
That is being repaired so I will need to see if that fixed it up. I need to vent the hood as well, both for added cooling and down force. The tough part will be making it look good.
#305
No and yes. I think it uncovered an issue with my over flow tube. So it did over heat last year, but as mentioned I think know what caused it. We were losing coolant on each time attack. 15-120 minutes on track with only a 30-45 minute break in between.
For the kind of power you're running you may want to run the steam vent ports to a surge tank and basically eliminate the "overflow" type if system. You can get a couple extra quarts of coolant in the sy6that way too.
#313
