how to get a 19 by 12 wheel to fit a 4th gen camaro ....
Old 02-02-2011, 11:43 AM
jb7241986's Avatar
Default how to get a 19 by 12 wheel to fit a 4th gen camaro ....
i know i posted a similiar thread last week but i want to run oem c6 z06 wheels on my ss so i can do the cts-v brake mod up front. wandering what i have to do to get the rear z06 wheels to fit with the 325-30-r19 tires.....would the bfh mod and cutting out the bumpstops do the trick? thanks.
Old 02-02-2011, 02:48 PM
jb7241986's Avatar
i saw that early 4th gen z with the setup i want......lemme know what i gotta do to run these big *** 19's out back pls
Old 02-02-2011, 02:56 PM
VinR1's Avatar
search for member '93formto98ta' (i think thats it)
he fit C5 Z06 18x12 wheels on his car - took some spacers and a ton of BFH'ing
chon79's Avatar
mini tub.
Old 02-02-2011, 07:48 PM
jb7241986's Avatar
to the top fellas .....
Old 02-02-2011, 08:43 PM
Swiat34's Avatar
I have C6 ZO6 wheels on my T/A. I had to cut the bump stops and their mounts off, cut a little corner of square-stock from the front of the wheel well, cut a section of the outside edge of the lower control arm (the fold-over) and BFH the hell outta the front of the wheel well. Also, the ridges along the inside face of the wheel well that spread out from the bumpstop need to be cut down their length and hammered flat.
Old 02-02-2011, 10:24 PM
jb7241986's Avatar
swiat you are the man.....i appreciate it much if you got some spare time and could take pics as to where i need to hammer and cut id be extremely happy. thanks for your input bro.
Old 02-02-2011, 10:31 PM
hitmanws6's Avatar
If you want to save some cutting and stick to a lot of BFHing, use spacers to kick the offset out to around 36mms or so
Old 09-19-2011, 09:58 AM
LSjim's Avatar
Im puttin on some 19-12 z06 spiders and it would really help if you had some pics of what to grind
thanks in advance
Old 09-19-2011, 03:18 PM
carlos64030's Avatar
Don't forget to take ride height into account.
Old 09-19-2011, 05:40 PM
Captain Double Post
BOBS99SS's Avatar
R0ll fenders
Old 09-20-2011, 03:43 AM
Mr.z/28's Avatar
someone on here by the name of strokerB had them on his LT. He said it took alot of BFH and no cutting or grinding of any sort but since those wheels have corvette offset, they stick out a little bit.
https://ls1tech.com/forums/wheels-ti...kes-355-a.html
There is a member on here that has a black SS I believe on gunmetal spyders. He got them from 6LE. Man that car is beast! I have a pic. here you go.
Hope he will chime in.
Old 09-20-2011, 05:30 AM
Captain Double Post
BOBS99SS's Avatar
that looks killer, i have seen a few 4th gens run the 19x12 rear so it can be done, i really like the c6 zr1 wheel alot more than the c6 z wheel though,
Old 09-21-2011, 04:46 AM
Mr.z/28's Avatar
Leave the multi spokes for trans am. They fit so well.
something simple like a 10 spokes fit a camaro well.
Old 09-21-2011, 07:25 AM
69TA's Avatar
what is the backspacing on the 12's?
Old 09-21-2011, 08:20 AM
That tire looks like it sticks out so far from the fender. You'd have to have an extremely stiff suspension setup to keep from making tire to fender contact.
Old 09-21-2011, 01:12 PM
LT4vert's Avatar
The OEM 19x12 Z06 offset is 59mm. With no spacer, it sits flush with the top of the wheel opening. Ive seen a couple cars that had alot of BFH and cutting with the OEM wheels, but I havent seen a car with OEM wheels and spacer like was mentioned earlier.
Old 09-21-2011, 04:06 PM
6LITEREATER's Avatar
A customer and friend did it with our 19x12 Grey Spyders. You need a spacer and longer stronger wheel studs (ARP, etc...) but it looks GREAT and now he hooks
Old 09-21-2011, 06:46 PM
salemetro's Avatar
What size of tire was he able to shoehorn in the fender wells?
Old 09-22-2011, 12:14 AM
Mr.z/28's Avatar
Id like to see which friend of yours did it.
Quick Reply: how to get a 19 by 12 wheel to fit a 4th gen camaro ....
