m&hs vs. mickey 15"
m&hs vs. mickey 15"
which tire will do better on street and track for a 15inch rim?
both in a 325/50r15
http://www.mickeythompsontires.com/s...ETStreetRadial
http://www.mandhtires.com/store.php?...on=show_detail
both in a 325/50r15
If you want more traction I would either do the 325 mickeys or the 390 M&H if you can squeeze a 30" tire under it, many have done it before. The 325 m&H are not going to be as sticky as the 325 mickeys if that is what you were asking though, but the 390 m&H should outperform both.
run slicks at the track so cant comment much there
