what tires for +1000RWHP ?
Old 02-19-2011, 04:38 AM
PONTIAC SLP's Avatar
Default what tires for +1000RWHP ?
Hi like title says , Searched and didn't found any result for my 2001 Trans Am , let me explain to get the point well .....
* Car has LSX 454 + lot of nitrous and will pulls above 1000 at the wheels , exactly 400HP of nitrous (Direct port system - Progressive setup )
I bought Mickey Thompson ET radial Tires and didn't tested them yet
It has full suspension , RPM full built Transmission T56
All the car equipped by AES Racing , they're sponsor here
All races will be high rolling above 70MPH to avoid spinning issues
*So what tires u guys recommend for this car ?
*More one question ( I have Torque thrust II wheels the rear size 17inch width 11inch ) 335 /35R17 tires will fit ?
Old 02-19-2011, 09:31 AM
SHovV's Avatar
get 18's and MT 345 DR's
Old 02-19-2011, 09:52 AM
I already bought a new wheels and tires , Can't change , let's see other opinions
Old 02-20-2011, 08:02 AM
pancho toco loco's Avatar
I dont see a problem running n/a at highway speeds and hitting it. Spraying it well I see wheel spin. From a dig good luck n/a and spraying.
Old 02-20-2011, 08:06 AM
Do recommend to run 335 /35R17 ? , these tires will fit my wheels ?
http://www.summitracing.com/parts/KUM-1793313/
http://www.summitracing.com/parts/KUM-2105813/
Old 02-20-2011, 10:44 PM
xXxSilveradoxXx's Avatar
I bought Mickey Thompson ET radial Tires and didn't tested them yet.
I think those are probably the best tires you can go with since you are staying at a 17" rim that's 11" wide. Although I do agree with SHovV, 345s would be the best way to go.
These tires may be 335s but the M/T 315s are are going to be stickier.
Old 02-21-2011, 07:24 AM
Nastyc4's Avatar
lol 1000 rwhp. sell the tires and the restof the car and buy an awd car. there's your answer.
Old 02-21-2011, 10:20 AM
venom ws7's Avatar
Old 02-21-2011, 10:23 AM
LS1RedZ's Avatar
Those should hook good if its setup right on the progressive controller. Thats a lot of damn power tho, especially on the hose.
Old 02-21-2011, 10:26 AM
Photochop's Avatar
Originally Posted by venom ws7
295/45/17
This. You're gonna have a heck of a time getting that much power to hook on a 26" tire. 27" or 28" will work alot better. But, the progressive controller should help alot, but the bigger tires will handle more of a hit
Old 02-21-2011, 10:36 AM
venom ws7's Avatar
If you can sell the TTII and get Billet Street Lites or something 15 in the back 28tall tires with your 4.10 it will work great from 3rd gear roll...
Old 02-21-2011, 12:26 PM
lonely's Avatar
++++1 ^^^
you don't need to go wider, 10.5" can handle the power, so why u need to go wider, as photochop said, u need to go with taller wheel, then consider ur suspension, weight transfer, and stay away from kumho.
finally don't shot nitrous through gears .
Old 02-21-2011, 04:32 PM
Tally TransAm's Avatar
http://www.mandhtires.com/store.php?...on=show_detail
bad *** tires
Old 02-22-2011, 01:45 AM
I was always under the assumption that taller tires on little 15s can get pretty squirly compared to a shorter sidewall tire.
Old 02-22-2011, 01:46 AM
SSmoken's Avatar
just spray half of that lol
Old 02-22-2011, 07:23 AM
Destroyer of Exotics
FlashWS6's Avatar
295/45/17
thats what I run on my car, similar setup but in a vette. however Il be trying out some some 305/45/18 mickeys for 2k11. I dont think you can ever have too tall of a tire at this power level.
Old 02-22-2011, 11:42 AM
LS1RedZ's Avatar
325/45/17 M&H radial. Has alot of sidewall and that will be good to handle that power. Im running them on my car, but I have about 200hp less than you.
Old 02-22-2011, 12:51 PM
venom ws7's Avatar
I agree 700+rwhp get the tallest tire you can get
Old 02-22-2011, 12:55 PM
jc98ss's Avatar
go fully tubbed.....pro street it
Old 02-22-2011, 01:03 PM
FlashWS6's Avatar
lol I'm gonna try these out, if i like em and they hold the power. Il stick with em and no widebody for now. if not il be going 345/18
Quick Reply: what tires for +1000RWHP ?
