Arp wheel studs
Arp wheel studs
Which one ARP 7708 or 7713, or anything else? Wheels are C6 OEWheels Offset, front 46mm, rear 56 mm. I need help in choosing the right studs as I want to put a 1/2" spacer in the rear. I already installed a 1" adapter in the front, looks flush. Now the rear looks a bit sunken in.
Thanks
Thanks
Thanks
Thanks
The 7708 are 2.5" long and work out perfect with a 1/2" spacer the 7713 are 3.25" long and will stick out too far.
I saw the pics of your car with those wheels, pretty sure 56mm in the rear is the same offset used on all the 18x10.5 OE wheels. I just installed the DD c5s on mine, and used a 5/16" spacer and the ARP 2.5" studs and it sits flush with the quarter panel. If you go with 1/2" spacer it will stick out past. I don't have pics yet, weather hasn't been nice when I've been off work to get anything yet. If you do a member search for 'hollo' on here, mine is setup exactly like his.
