Weld RTS 15x11.275 on narrowed rear
ok guy my rear end is narrowed 3inches per side i no on the 10 inch wheel i would need 4.5 back spacing, what would i need for an 11 inch wheel?
At least 5.5. Because of the extra .275... maybe even a tiny bit more. I'm assuming you've already gone BFH. If not, I assume you're prepared to, lol. Show some pictures when you get it all done.
I guess I should also add the bump stops are long gone seeing its on a camaro I don't want the wheels to stick out much, I guess I could just ask one a regular width rear end what backspacing would I need to have? If the wheels are gunna stick out I will just go with a 10 inch rim.
