billet specialities ??
Old 04-04-2011, 08:44 PM
kevins2000LS1's Avatar
Default billet specialities ??
Does the NON F-BODY spec wheels fit stock brakes 15x10 with 5.5 backspacing? If not do they have fbody spec with that backspacing?
Old 04-05-2011, 07:00 AM
Anyone at all??????
Old 04-05-2011, 07:44 AM
LUNATIK LT1's Avatar
everyone is still sleeping.
Old 04-05-2011, 09:49 AM
Brakemotive's Avatar
I would call their tech line, they should be able to answer that no problem 708-588-0505
Old 04-05-2011, 02:25 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
There was a guy on here that ran the 15x10 with 5.5 backspacing but if I remember right he had drag brakes on it. You may be able to grind the calipers and make them work
Old 04-08-2011, 10:46 AM
fastbillet's Avatar
We only offer the F-body specific wheel in a 7.5" bs... the reason being is most guys with a narrow rearend use drag brakes.... you can gring the calipers to make them work just like you would with a weld...
Old 04-08-2011, 11:48 AM
wheelczar's Avatar
Default Grind Brakes
Not all Weld require grinding brakes. Just their sport forged wheels. They have been making those wheels the same way since the 1970's.
The RT-S is designed to clear the brakes with no mods.
Old 04-08-2011, 12:39 PM
Yeap I just ordered some rear RTS!
