18x10 enough rim for a Nitto NT05 315/40 drag radial?
Ive been researching and I can't seem to find anyone that has these tires on a 10" rim. Ive seen 9.5 and 10.5....It says they need a minimum of a 10.5 rim and I know thats usually a suggestion. Would a 10" rim be enough to properly fit this tire on and be safe?? I dont want to run a 305/45 because its too tall and too sloppy on the highway..and I cannot find any other DR in this size. If not im gonna go with the 325/40/18 M&Hs because they run really skinny and seem to fit absolutely perfect on a 10" rim they are just ugly...
The pic below is my 295/35/18 nitto nt05(non drs) on a 18x10 wheel. I think they fit perfect and a 315 is about 3/4in wider than these tires so id say go for it, aslong as you're not taking super corners you should be fine.
