need a 28" tire for 17x11 rim
Old 04-24-2011, 04:32 PM
SKULL's Avatar
Default need a 28" tire for 17x11 rim
need a drag radial for a rear set of 17x11 rims and needs to be a 28 inch tire.
what do you guys think my best choice would be ?
Old 04-24-2011, 09:03 PM
nasty96's Avatar
the onlything i can find is what i have on my car M&H 325-45-17.
Old 04-25-2011, 05:29 PM
SKULL's Avatar
did you have to do any cutting or anything
Old 04-26-2011, 06:44 AM
LS1RedZ's Avatar
Im running that same M&H. I already had my fenders rolled and I beat the inner fender wells in. Other than that they fit fine.
Old 04-26-2011, 08:22 AM
DTB_LS1's Avatar
I've got MT 295/45/17 the measure in at 27.2".
Old 04-26-2011, 08:39 AM
krobinson123's Avatar
I also have the MTs 295/45/17, not quite 28s but they are about the same width as the M&H 325. The M&H 325 is also a good choice.
Old 05-22-2011, 12:00 PM
1961ba427's Avatar
Does anyone have some pics of the 295 / 45 - 17's on their car???
Old 05-22-2011, 02:40 PM
uscg02ws6's Avatar
Toyo makes a 345/40/17 drag radial that is 28 inches tall but its a really big tire u'll prob need a mini tub. i tried it on my car and there was no way it was going to work
Old 05-22-2011, 02:59 PM
mikep2002's Avatar
subscribing! I am starting to like this M&H tire...
Old 05-22-2011, 10:47 PM
airforcemanss's Avatar
i want to run the sizes that have already been mentioned in this thread. 28" height, doesn't that make the ABS INOP act up or something? something that has to do with a 2" tolerance between the difference of the front and rear tire height; it triggers it from what i've read...
Old 05-23-2011, 04:28 AM
You are correct. You will have to disable the ABS (I pulled the fuse). If you don't, the ABS will activate anytime you brake slightly halder than normal.
Old 05-23-2011, 04:50 AM
Posi's Avatar
Nice squat on that Vette Mike!
Old 05-25-2011, 01:52 PM
This kind of blows, i have my mind set on them 295//45/17...i really don't want to run a 315/35 series tire...
Hypotheitically, if i do the SJM delete kit, can i use a proportion valve to adjust to more of my braking style? I am as green as it comes with this FYI
I'm going to pull the fuse today and see how she feels for about a wk or so...this is ABS tolerance thing has put a hold on a bunch of goodies
Old 05-25-2011, 02:12 PM
1961ba427's Avatar
I hear that.....I want to remove my ABS and do a line lock.....along with not having issues with a custom rearend swap....and pull the air bags....BUT I'm sure a few of my kids will end up driving this car on the street and I just don't know if I want them driving it if it's not as safe as it could be.
Old 05-25-2011, 04:02 PM
'02TA's Avatar
I had M&H 325's and they were a real nice tire
Old 05-25-2011, 06:26 PM
^ the racemasters is the tire i really want to run but i'm aiming for 15k+ for mileage...how long did that last you?
From what i've read, those tires point inward a little and if you roll your fenders with a lil BFH mod you should be good
Old 05-25-2011, 06:34 PM
Fast T's Avatar
I would go with the M/T 295x45x17.
Old 05-27-2011, 11:35 AM
'02TA's Avatar
I had the original ones that are on the narrow side so I never had a problem with fitment. I only had them on the car for a while because I put regular street tires back on. I was selling the car and I wanted the person who bought it to have functional ABS. I put maybe 3k miles and 4 passes on the tires max and they still look brand new. If you don't travel highway much you could probably get 10k...maybe. It depends on your driving. I still have them actually and they might end up on my current f-body
Old 05-27-2011, 02:30 PM
uscg02ws6's Avatar
here is a pic to show u guys just how big the 345 toyo tires are the bald tire is a 315 Mickey Thompson.
They are going to look good when i get the $$ to do a mini tub but there is no way they would fit with out tubing the car
Old 05-28-2011, 12:58 AM
BADBOYZ28's Avatar
I have the Toyo 345's on with no mini tub. Took some cutting and banging but there on.
Quick Reply: need a 28" tire for 17x11 rim
