Anyone with weld rts wheels, come inside
Old 05-02-2011, 08:28 PM
25thhawk's Avatar
Default Anyone with weld rts wheels, come inside
What length wheel stud are you using and how far does it protrude through the lugnut? Trying to figure out what length wheelstud will be legal for my new rearend. Thanks
Ryan
Old 05-02-2011, 09:05 PM
jmm98LS1's Avatar
I have 3" studs and about a .5-.75" is sticking out past the lug.
Old 05-02-2011, 09:37 PM
NOS LS1's Avatar
Default Rt-s
Weld RT-S wheels are Drilled / Designed to run 5/8" x 3" long studs with a standard through hole nut on the 5/8" dia. stud.
If you run 1/2" dia. studs or the standard metric studs...
You are supposed to run the 1/2" mag style or metric ( closed ) style nut with a 2" long stud. This is what weld told me on the phone.
Attached Thumbnails Anyone with weld rts wheels, come inside-midwest-chassis-fab-9-break-oil-change-002.jpg
Old 05-03-2011, 12:02 AM
J-Train's Avatar
+1 This
I am on factory OEM lugs with the shank style mag lugs and washers and they work just fine, plenty of thread. But I only got bolt ons so no extreme HP
Old 05-03-2011, 07:01 AM
LS1RedZ's Avatar
Sorry to thread jack, but where is the best place to order some Weld RTS' from?
Old 05-04-2011, 06:58 AM
SmokedOutZ28's Avatar
Where is a good place to order the lugs with washer permanently attached? It's a bitch trying to keep the washers from spinning off the lug nut when you have the long stud + deep backspacing.
Old 05-04-2011, 05:21 PM
outtacontrolz28's Avatar
I ordered my wheels and lugs from Jegs...wheels were $985 shipped to my door...and only took 2 days to get with the free ground shipping.
Quick Reply: Anyone with weld rts wheels, come inside
