ive searched but i still have ?s
Old 05-03-2011, 07:48 AM
edub80's Avatar
Default ive searched but i still have ?s
I just recently came across a good deal on some 28/10.5/15 slick.... what is it I have to do to get them to fit on my car
Old 05-03-2011, 07:52 AM
carlos64030's Avatar
Get them mounted on wheels.
Old 05-03-2011, 08:05 AM
edub80's Avatar
Lol... I know that... I mean will they rub or will they clear
Old 05-03-2011, 08:10 AM
babbage1109's Avatar
What wheel are you puttin them on. What's the backspacing of the wheel stock rear end or what. Break it down and give details more than Just the tire
Old 05-03-2011, 08:16 AM
edub80's Avatar
Stock height and stock rearend.... Gota order some racestars... 15x10 with 7.5bs...
Old 05-03-2011, 08:33 AM
Clyde H Frasier Jr's Avatar
What is the tire size (325-50-15) or what?
If they're 325's, your going to need to roll the wheel well and do a little massaging on the enter portion of the fram with a hammer. The bump stop will probable need to be shaved a little.
Just find out the backspacing and when you order depending who you go through ask about needing a spacer or anything like that. Depending on the backspacing you may be okay but it just depends
Old 05-03-2011, 08:41 AM
I said depends like 10 times lmao.
Old 05-03-2011, 08:44 AM
edub80's Avatar
All it says on them is that they 28/10.5/15..... m/t drag slick.... I really don't Wana do any cutting or rolling.... so I mite just end up selling them if that's the case
Old 05-03-2011, 08:46 AM
edub80's Avatar
Lol @ babbage
Old 05-03-2011, 10:29 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
If it is a full slick then it will grow with speed. You'll have to trim the bumper
Old 05-03-2011, 10:40 AM
edub80's Avatar
Guess they will be for sale then... thanks
Old 05-03-2011, 06:34 PM
edub80's Avatar
does anybody have pics of what kind of modifying i would have to do?
Old 05-03-2011, 06:36 PM
You may want to try the drag racing tech section
Old 05-03-2011, 07:04 PM
edub80's Avatar
ok i will check over there... thanks
Old 05-03-2011, 07:17 PM
Camaro396's Avatar
It's a bias ply tire so it will grow at least 1" during burnouts and tire speed. You will need to trim your bumper for the added clearance for the tire to grow. I see your sig says A4, being an automatic, drag radials will work out fine for you.
Old 05-03-2011, 07:18 PM
Camaro396's Avatar
Also with 3.73s I'd stick with a 26" tire unless you're spraying it a lot.
Old 05-03-2011, 07:25 PM
edub80's Avatar
well i just put them up for sale on here...maybe somebody will buy them...i dont want to do any cutting and rolling of the fenders
