WELD MAGNUM 2's
WELD MAGNUM 2's
Im wanting to go from running pro stars to Magnums on my f-body, Ive heard that you have to narrow the rear a little to run the Magnums, is this so... Could I run a spacer in meantime? Also anybody have any pics of the Magnum 2's on there f-body?
Thanks!
Thanks!
You don't have to have your rear narrowed, they just don't come in a backspacing as deep as the Prostars do. The deepest backspace you can get the Magnum in is 7.00" where as the Prostar comes in 7.50" backspace. So basically, they will stick out a half inch further than your Prostars currently do. A spacer wouldn't work because it would just push the wheel out even further.
