as long as they bolts patter is 120 they will fit. not sure about the offset tho. 120 is like bmw wheels, used them on fbody with zero issues. they looks nice too imo.
The wheel bolt pattern is off by .325 mm at each wheel stud, it'll work because the difference is so small. The offset is good so you shouldn't have any issues with the tires rubbing;anywhere.
