Need help!! (pics)
Need help!! (pics)
I have been trying to put these studs on for almost 4 hours now and no luck. There isnt enough room for me to put the stud in. How do I remove the hub?
also trying to install intrax lowering springs in the rear. The jackstands are under the frame and the rear end is hanging loose. Everyone says that you give a little tug and they come out. NO, i have been prying the **** outta them for a while and they wont pop off there little perch.
-----Also does anyone know why the springs wont pop out like everyone else's?
As said above remove the c-clips and pull axles out enough to install studs. and i have removed and install over 10 sets of springs on f bodies and never done more than jack it up and pry them out.. keep trying you'll get it.. good luck
So, I remove the diff cover and looks for c-clips, remove them, pull out axle enough to put studs in, re-install c clips, make new gasket for diff cover, then re-fill diff?
Check if there is a hole you may have to rotate the ends to line up the stud hole and you can slide it in from the back. The fronts are easier theres no lining up in front.
use a big flat screwdriver or crow bar and slip it under a part of the spring at the bottom to see how much tension there is. Should be able to lift it a little and slide the bottom off the perch.
I dont have the c-clips because mine is the Moser 12bolt. All I think I have to do is loosen the 2 bolts on each side of the diff?? Sorry trying to be extra safe because this is my daily driver and dont wanna do this twice
