sprot wheels and tires for 2006 LS2 corvette?
how wide can i go with a set of 19" wheels and tires front and rear that i can fit perfectly in a 2006 LS2 corvette? what is the corresponding offset and backspace? i'm thinking in the ROH modena wheels.
stock wheels are 19 X 10" rear and 19 X 8.5" front, stock tires are 285/35ZR19 rear and 255/40ZR18 if i'm correct.
thanks for help.
thanks for help.
Captain Double Post
well the zo6s run a 19x12 in the rear, i dont see why you couldnt go up to a 12 inch wide in the rear, but do your vette a favor ccws or bust, there is no better looking wheel for a vette or a trans am , im sure a vette guy will chime in and give you better info on offsets and backspacing,,, good luck with the wheel search ,
i found info on backspace and offset at tirerack website :
http://www.tirerack.com/wheels/resul...Standard+Model
any one has info on offset and backspace if i go with widest possible 19" wheels and widest possible 19" tires front and rear in standard 2006 corvette.
