Help me with my stance looks cool on vdubs but not this ahhhhh
So i got my car about 2 months ago. love it overall but GA damn whats up with this front stance ?
They look like the c5 replicas from OE Wheels.
Fronts appear to be 17 x 9.5
But for some godawful reason there is a 2 inch spacer !!!!! wtf ?
Car is lowered on eibachs i was told.
From the looks of things i have about an inch to spare before it rubs
If you have a 1998 -2002 trans am with these wheels please post pictures and tell me how you solved this problem i am having !!! Im going ape **** over here
Need my car to stop looking like this
thanks
_ dante
thanks
_ dante
but i was told it will rub and thats y the spacer was on in the first place... and by looking under the car when its on a lift it looks like i only have an inch
could these for whatever reason be a 8.5 inch wheel ?
The reason why it looks like it will rub on a lift is because your suspension is not loaded. When your suspension is loaded with the car on the ground, you will see it clears the spindle cleanly.
get rid of the spacer, put the rims back on and see if they rub...if they rub, get a smaller spacer then what is on there. Plenty of people run 17x9.5 inch rims including myself without any issues at all.
offset is a + 45 but its got this massive papper weight spacer 2 inches thats + another 50 mm. so its + 95 wtf
i can keep the wheels then do a + 10 mm spacer be at +55 and it should do fine ?
would i need longer studs for this to happen ?
based on this thread i need to fall in between 50- 56
https://ls1tech.com/forums/wheels-ti...must-read.html
