What size spacer do I need to make the front wheels flush with the fender?
Old 09-22-2011, 01:45 PM
Lizard King's Avatar
Default What size spacer do I need to make the front wheels flush with the fender?
My front wheels are 18x9.5 Deep Dish C5's with a 54mm offset. I'm gonna lower the car with Koni 4/4's and Strano springs soon and I want the stance to be perfect (to my taste anyway).
Would a 20mm (3/4" I think) spacer do the trick? That should bring the offset down to 34mm right?
I understand the camber setting affects things too? Obviously I'll have the car aligned once it's lowered but that stuff kinda goes over my head.
Old 09-22-2011, 02:27 PM
ChrisRZ28's Avatar
I've got 17x9 1/2", 56mm, ZR1s. I run a 3/4" spacer (I have ARP studs) and the top of my wheel/tire is a 1/4" inside the fender. Hope this helps.
Old 09-22-2011, 02:29 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Get them mounted on the car first, then measure and buy accordingly.
Old 09-22-2011, 08:46 PM
VinR1's Avatar
ChrisRZ28, can you post a pic of your car? Ive got the same wheels and want to run a spacer
Old 09-23-2011, 01:11 PM
ChrisRZ28's Avatar
Originally Posted by vinr1
chrisrz28, can you post a pic of your car? Ive got the same wheels and want to run a spacer
This is my first attempt at pictures so I hope this works. It may be kind of hard to see, but the top of the tire is a 1/4" inside the fender. I got these spacers from Summit or Jegs. They're the universal ones. I've had them on the car for a few years now without any trouble. Edit:yes my front tires are shot.
What size spacer do I need to make the front wheels flush with the fender?-100_3177.jpg
What size spacer do I need to make the front wheels flush with the fender?-100_3178.jpg
Old 09-24-2011, 10:17 AM
Wing Zer0's Avatar
^^^X2This, and a link on how to.
http://www.trakplus.com/measure
Quick Reply: What size spacer do I need to make the front wheels flush with the fender?
