17x11.5" ZR1's
17x11.5" ZR1's
I have 4 17x11.5" black ZR1's...now my concern is would it fit on all four corners? or should I do a mix of my current chrome ZR1's that are 17x9.5 (11.5" rear and 9.5" front)? of course I would paint the chrome ZR1's black. And for all of you wondering...which ever way works out for my car I need to sell 4 of these wheels and tires so that's just a heads up in case anyone is interested.
1 Post
OP, I would keep it clean and simple with the 9's up front and the 11's in the rear cause imagine having to buy tires for 4 11's every time you needed em. At least with the 9's up front, you can cut your costs a little bit plus it'll look better. Just my $0.02 though. There yours so what ever you like.
There's a little bit of info in the Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!! sticky, although it indicates you can't do 17x11s on the front. It CAN be done, but some mods are usually necessary. Check out the pinned thread in the Wheels & Tires forum over on frrax.com for how to do it. Me personally, I'm running 18x10s all around and clearance is a non-issue even at full suspension travel and wheels turned to full lock. I have room to go bigger but offest starts becoming more critical. Especially regarding the clearance to the upper ball joint nut.
Good Luck,
Mark.
Good Luck,
Mark.
Mark.
275 on an 11" wheel = fail. Run 315s or put some 9" back up front.
I run 315 nitto nt555 at all four corners, 17x11s with 50mm offset with a 1/4" spacer on the front with the spindle casting nub ground off and they clear just fine.
Lots, UMI k member, UMI chromoly lower a arms, Edelbrock IAS coilovers with 600# springs, LS1 spindles with the casting nub ground off, a touch of negative camber. The rear I have UMI adjustable LCAs, UMI TA, Firestone R9000 air bags @ 27psi, and a bunch of stuff cutoff, fender lips rolled, and a watts link
you must have your Rim dimensions confused. i dont know how you got a 275 on a 11 rim. myself has never seen this either.
