I need skinny tire size suggestions please.
The tires I currently have on my skinnies are 165/80/15 but I can't find that size any longer. I don't need the expensive front runners because I don't plan on using them much. What are you guys running?
Thanks for the reply and the suggestion. I'm really looking for an inexpensive street tire to stick on there for a few passes. I think I only paid $100 combined for the last 2 I got. I believe they were volkeswagen beetle tires.
Captain Double Post
i run a nexen , i think they are close to 60 each, i know there are of guys that say stay away from mixing tires but i have ran the nexens for 2 years with out any issues, there are a few other guys on here that run them, but if your at the track alot ,or running at high speeds its worth it to pay for a better tire, but i can get you the size and info on what i have if you like
May god be with you while you endanger your lives and others on the strip next to you with your 3,500lb F body on volkswagon beetle tires speed rated at 95mph and 2,000lbs max. Plenty of people have "not had a problem" with them, but others have, I personally had one of mine blow out on my Camaro. Luckily, I was only going 45mph or so and it wasn't a bad accident. I will never run a tire on my car aside from one made specifically for what I intend to use it for. Your safety and others around you isn't worth your broke *** trying to save 100 bucks. If you can't afford to run the proper safety equipment or tires on your car, then you don't belong behind the wheel of a racecar. Not trying to be a dick, just saying save up for the right ****. I can't believe the amount of people that will spend big money on their cars but cut corners on some of the most important factors of their car.
Thanks alot for the info. I'll look into these.
Ok so because you had one blow out on you, everyone else becomes a hazard to your safety. Like I said, my plan is to only run on the tires a couple times in order to get a new best while the good air is here. I prefer to run on my 17" SS rims. I don't find it necessary to spend $300 on a set of tires I will only run a couple times!!! And yes, you are coming off as being a Dick! There are far better ways of expressing yourself than the way you just did.
