Whats it take to fit a 12'' wheel?
Old 12-09-2011, 02:27 PM
mr_biscuitz's Avatar
Default Whats it take to fit a 12'' wheel?
What is all needed to fit a 12" wide wheel in a stock width rear? Wanting to keep the tire in the same location as stock. What backspace is needed? I know you need a mini-tub but what else is needed?
Old 12-09-2011, 06:20 PM
2FNQUIK's Avatar
58/56mm offset, tubular lca'sor madman offset LCA's, adj. panhard
Old 12-09-2011, 06:38 PM
have everything already, just curious if it can be done with a stock width rear? I dont think it can but im not sure, from my research it seems like the rear would have to be shortened. I can move some brackets around and such but not really interested in changing out the rear end right now.
Old 12-09-2011, 07:13 PM
carlos64030's Avatar
I have 13" wide wheels and my axle is all stock.
Old 12-09-2011, 08:40 PM
If its possible with a mini tub, what wheel backspace is needed to fit the tire inside the wheel well with a 15x12. Right now I have a 15x10 but about to buy some new wheels and wanting to go the 15x12 route if I can over the 15x10.
Old 12-10-2011, 12:53 AM
Blk98Vert's Avatar
Yes its possible with a lot of hammering and offset LCAs. The C6 ZO6 backspacing and offset will work
Old 12-12-2011, 06:17 PM
1 nasty z's Avatar
Pics or it didnt happen!
