best tires for a street car?
Im putting nt555s on the rear at 305x35x18 i am going to run a 285x40x18 up front should i go with the nittos up front or something cheaper and less grip?
^This.
Your front tires do your turning and braking, why do you want less grip for this on the street? The only time that you should want smaller front tires is going straight down a drag strip. Yes larger tires create more rolling resistance, but a near stock width 285/40R18 tire is good balance for the street with a 305/30R18 rear. Too narrow on the front with too wide in the rear will create a lot of understeer. Only a 20mm (less than an inch) difference in front/rear widths should have a good handling balance, depending on your suspension/sway bar setup.
Nitto 555's are not known for grip at all, they are just street tires, only the 555R or 555RII's are the grippy tires.
Why would u spell camaro wrong? But thanks bobs99s, i guess i didnt look at the tire very well but i was gonna get fronts the same as the rear and i got nitto extreme drags i just thought they seemed pretty soft
I see where your coming from OP. I don't think you meant to say you WANT less grip, more so that your assuming with a cheaper tire your automatically going to have a less sticky tire (this is most of the time true). I would say Nitto 555's are a good choice for up front, but it really depends on what your doing with the car. If your doing a lot of racing on the street or overall more concerned with drag racing you can get away with something a little less grippy up front. Like someone stated previously Sumitomo's are generally a cheap tire that don't have much grip but may be suitable for front wheel duty.
I've got (older) 555s on mine right now and they arent too bad. It looks like the price difference now between the 555s and 05s are enough where it wouldnt make sense to buy the 05s. although prices im looking at are for 275s not 315s
