What is the proper backspacing for drag wheels ?
I need to order drag lite wheels as soon as possible
I need 15 X 10 in the rear and 15 X 4 in the front
I know that the wheel pattern is 5 X 4.75 but
I want to know what s the proper backspacing for the 2001 firebird
I think it is 7.5 or 6.5 in the rear
and what about the center bore diameter ?
thanks in advance
thanks in advance
You need 7.5 in the rear with a 15X10... Even then with some rims (pro stars drag lites) you will still need to grind the calipers and most likely run a spacer with stock ls1 calipers.
275s should be an issue.. You *might* have to roll the fenders but I *highly* doubt it, especially on a TA. You shouldn't need LCAs either but I'm not sure on that.
Ok is this the correct part number for the rear
http://www.summitracing.com/parts/WLD-96-510284/
also do i need to order lug nuts or the factory nuts will work ?
Are your brakes stock? If so I'd look into the RTS wheels from Weld. They're only a few bucks more than the prostars and will fit over your brakes without grinding them down like you would have to with these Prostar wheels.
-Lance
Factory lug nuts will NOT work. Weld wheels use a shank style lug nut, not a acorn style.
-Lance
-Lance
I was also going to recommend some slightly more expensive options. I bought my race stars brand new with brand new tires for 950$ shipped.
Ok one last Question will i have any problem if i bought those
http://www.summitracing.com/parts/SUM-571-5862PS/
with those tires
http://www.summitracing.com/parts/MTT-3753R/
and if you can give me a link for the lug nuts for those tires
i don't have the budget for the welds right now
with those tires
with those tires
with those tires
With minor modification (grinding calipers/spacers) those should bolt right up and go, you shouldn't even need aftermarket LCAs.
You can pick lugs up at local parts store.
Are you replacing the studs or running factory studs?
Because with non fbody specific rims you would have to grind the caliper so much to make them fit it would be unsafe. Some people believe grinding it at all makes it unsafe so they go with a rim a bit more pricey to avoid this.
