got the weld rts and they don't look like they fit any help?
Im in the middle of building this car and the rear end is a mwc fab 9 that is -2.5 on either side, the rear rims i ordered are 15x10 with a 5.5 back spacing looks like as soon as a tire gos on the rim they will hit the lca and the bump stop, anyone have any ideas before i get out the bfh!!!!
That's what I'm thinking but I can't figure out how, it should be to the fender 1/2 inch with the 5.5 bs.... Also these 15x10 weld rims measure 11 1/2 inches outside to outside
Stock rear axle uses 7.5" backspace..so if you cut 2.5 off the rear end, to put the wheel in a stock location you would need a 5.0" backspace to put the wheel where it would sit correctly. You will probably need a 1/2 inch spacer, or send them back and go with 4.5" backspace.
1 Post
I wouldnt run that big of a spacer if you plan on racing it. Thats a lot of stress on studs. Cut your bump stops off that will help for sure, but I would get a different back space. Iv got 5bs on mine with 2.5s cut off each side and I had to do a little work to get them to fit.
I didn't really even think about it when I ordered them I told them what the rear end was and that's what they told me to go with (Jim himself at jims racing wheels) so I took his word for it, so if I get the 4.5 it should bring me off the bump stop more?
I have already talked with them and they said they will swap them out so I'm not worried I just want to do it right this time, sucks these rts don't come with a 5 bs
You are going to have to cut the bump stop mount and you may have to modify the the front of the inner fender well. Scroll down once you open the link.
https://ls1tech.com/forums/drag-raci...-build-11.html
To cut the bump stop, I used a sawzal and 4" hole saw.
