2001 TA WS 6 - Original Tire Brand?
Can someone tell me what the brand/model of tire that came standard on a 2001 TA with the WS6 package??
I do know the size is P275/40ZR17.
Thanks!!
Thanks!!
In their defense they get a terrible reputation on here for their lack of traction from a stop. However, that really isn't their design intent. They are really a handling and rain tire. I had Michelin XGT-Z4's which were a very similar design intent tire. Marvelous in the rain, handled very well. Once the car had extra power, I could annihilate them at will.
LS1Tech Administrator
Received 1,483 Likes
I don't know why GM used this tire for these cars. I too was not impressed with them. During that era, Goodyear was still making the GSC in a 275/40/17 size, and GSCs were a better performance tire than the F1-GS in my experience. GSCs were already a factory option on the 16x8 wheels, so I don't know why they didn't use them for the 17x9s as well.
I can shed some light. A 275mm width in a 3400 lb car....that says it all to me. That means you NEED water evacuation. They likely did it for general public safety IMO. If you have a wide tire, you need lots of weight to force the water out on the hwy, if you have a lightweight car, then you need a thin tire to act like a pizza cutter through standing water. A fairly light car with wide tires is good in the dry, bad in the wet. A light car with narrow tires is good in the wet, and bad in the dry. Not everything is about all out dry weather performance. This was a mass produced vehicle gentlemen.
The GS-Cs were an OEM approved tire that had already been assembly-line issued on C4s for several years in various size combos depending on year and trim level (255/285 F/R, 275/315 F/R, and 275 all-around). I had GS-Cs on my 16" stock wheels for a while, and they were better in every way than the F1-GSs that came on my WS6.
Having said that, the GS-Cs were never meant to be a snow tire, which is why the RS-A was also offered on the 16" wheels for all-weather purposes. So maybe the F1-GS was considered a better potential snow tire than the GS-C...I don't know, as I never drove on either of those tires in the snow.
The GS-C was a much older design as well. I think it was phased out in the late 90's (maybe early 2000's). They are also left/right specific. I imagine Goodyear wanted to supply their newer design. As a factory tire, that needs to avoid evil/unpredictable characteristics for your average driver, it does its job.
At the very least, they could have offered an optional second tire type for the base SS/WS6, just like the RS-A/GS-C option on the base model V8s.
In this day of lawsuit-itis, one jerk who whacked a curb because it was raining, and his tires just didn't turn, would have cost GM millions. It's not worth the risk for them. YOU want something that "hooks up" rain be damned, then YOU'LL install it, and GM will be in the clear...
Interesting because I witness this kind of thing, not tire design but overall platform balance, when switching to different DDs. Our roads here are shitty, and the 18 wheelers leave huge dips where your tires drive and it is prone to holding standing water. I used to daily a small car that was 2500lbs and had a 185mm tire. Looked like a damn spare donut Lets estimate for simplicity sake that it is a 5.5 inch rim. So that's a total of 2500 lbs per 22 inches of total rim width. That comes out to be 114lbs per inch of rim width. Common sense tells you a light car will want to hydroplane, but not so with this vehicle. Now lets compare to a Camaro with 275s @ 3500lbs. We will say they are 9 inch wide wheels. So we have 36 total inches of wheel width for an estimated 97 pounds per inch. The centerline of the wheel on the compact would need to push (evacuate) water in either direction a total of 2.75 inches @ 114s per inch. The Camaro needs to push the water almost twice as far at 4.5 inches with only 97 pounds per inch. Thinking about things like this shows how a 3500HD truck with 275s can maintain traction while driving through water because the weight per inch of wheel would likely be twice as high as a Camaro with the same width wheels AND have larger water channels.
