just snaged some prostars
Just snagged a pair of prostars with hoosiers already mounted on them. I've still got stock length studs in the back of my 12 bolt. What lug nuts should i order to make these work? I know i need shank style nuts whats everyone run? and where can i get the longer studs as well?
i would suggest running a longer stud... I just upgraded my studs to 1/2 studs just to be safe and you can get the correct lug to match its the open ended shoulder style or shank style they call it .
what length studs will i need i know they need to be flush or stick out of the nut. also where can i order them from? i haven't seen open ended shank nuts in the local auto store i worked at. I figured i'll probably run into a spacer issue once i get them all lined up i'm also sure i'll probably have to do some grinding.
Captain Double Post
Summit has them, there cheap, summits will do the job but rust quick but i think there like 6 bucks for 4, you will also need to grind your calipers, i forget what size spacer i have on there but im sure ya can search tech and find out,this topic is brought up everyother day, you can also order the studs/spacers n lugs all at summit
