wheel spacers on the front?
Old 04-01-2012, 09:50 PM
rcoers's Avatar
Default wheel spacers on the front?
Yes, I did do a search first
Thinking of buying some of the Eibach 15mm hubcentric spacers for the front wheels. Are they safe? (assuming I use a longer stud). Any info would be great!
Old 04-02-2012, 12:50 PM
rcoers's Avatar
Anyone?
Old 04-02-2012, 01:10 PM
bluedevil500's Avatar
I've been running 12mm spacers for over 2 years now. I've had over a dozen track days and even more time at the drag strip. Haven't had any problems. Eibach and H&R are both reputable companies. Just make sure you use the provided extended studs/lugs.
Old 04-04-2012, 04:20 PM
NXPRSS's Avatar
i ordered the eibach 15mm spacer since im doing the cts-v brake upgrade, and they came with longer studs... i havnt put them on yet... but seems like everyone running the cts-v brakes are running the eibach 15mm spacer.. and have heard of no problems with them!
Old 04-04-2012, 06:07 PM
02TransAm/Batmobile's Avatar
If you are running longer ARP-quality studs and they are torqued down correctly, does it matter the quality of the spacer? I'm using the cheapo Doorman from Autozone.
Quick Reply: wheel spacers on the front?
