question about tires
Old 04-01-2012, 10:56 PM
tvg001's Avatar
Default question about tires
i have a firebird with stock 16 tires its been sitting on them for about 1yr not moved do i have to get them replaced or will they be ok for a while they still have good thread n one kept going down so i would put air on it every once in while
Old 04-01-2012, 11:01 PM
MRMonster's Avatar
Check to see if there is any cracking on the sidewalls or tread. But you should be fine.
Old 04-01-2012, 11:17 PM
JDECO's Avatar
the only common issue is flat spots in your tires. If the tires sat low on pressure for an extended time
