R 315/45/18 F 295/45/18 or R 305/40/18 F 275/40/18
Old 04-02-2012, 09:16 PM
98z28CamaroJG's Avatar
Default R 315/45/18 F 295/45/18 or R 305/40/18 F 275/40/18
I plan on getting new rims and tires soon. I want NT05Rs in the rear and NT05s in the front. I just don't know what combination to go with.
With 18x10.5 in the rear, should i run 305/45/18 or 315/40/18 NT05rs?
In the front should i run 18x10.5 with 295/45/18 or 295/35/18 NT05s, or 18x9.5 with 275/40/18 NT05s?
Which setup is the best?
Can I have a 45 height in the rear and a 35-40 height in the front? What are the benefits and drawbacks of doing that? I don't really understand the benefits/drawbacks of smaller/larger tire heights and staggering them :-\
Car will be putting down 700+rwhp
Old 04-03-2012, 11:10 AM
SSCamaro99_3's Avatar
If you try to put a 28 inch tall tire in the front you will probably have rubbing issues.
Old 04-03-2012, 11:37 AM
02TransAm/Batmobile's Avatar
I would go with:
315/40R18 in the rear
275/40R18 in the front
I am running:
295/40R18 in the rear
Almost the same setup except the 315 will be 0.63" taller than my 295's. I'll get pics of this set up if you want.
Old 04-03-2012, 03:04 PM
Brandon331's Avatar
im thinking about running a 315/40r18 as well any one have any pictures?
Old 04-03-2012, 03:06 PM
Brandon331's Avatar
i ran a 305/45/18 one time hated it for the street hooked great but scrubbed alot im lowered 2'' too though
Old 04-04-2012, 02:08 PM
I'll definitely stay away from 28in then thank you!
Pics of that setup would be mic appreciated thank you!
Why was the 315/45 bad for the street? What did you switch to and how is it better?
Old 04-04-2012, 02:09 PM
Anyone know if I will have any fitment issues if I go 295/35/18 on front with 18x10.5in rims?
Quick Reply: R 315/45/18 F 295/45/18 or R 305/40/18 F 275/40/18
