PLEASE HELP!! will c5 deep dish 18x9.5 corvette rims fit my 2001 camaro?
Old 04-19-2012, 09:00 AM
Murphdizzzl's Avatar
Default PLEASE HELP!! will c5 deep dish 18x9.5 corvette rims fit my 2001 camaro?
I currently have 20x8.5 forte rims on my 2001 camaro and they r rubbing and making a really loud grinding noise i have no idea whats making it so i wanted to go down to 18 and found the c5 deep dish corvette rims 18x9.5 and i know alot of people on here have put the same size rims on here so i was wondering what i need to do to make them fit with no rubbing when i turn? thanx
Attached Thumbnails PLEASE HELP!! will c5 deep dish 18x9.5 corvette rims fit my 2001 camaro?-photo.jpg
Old 04-19-2012, 11:38 AM
Z Fury's Avatar
They fit without rub, assuming they are OE Wheels.
Old 04-19-2012, 03:16 PM
yes sir they r. and i was thinkin bout lowering it an 1'' to 1.2'' with eibech lowering spring would it rub then? and when or if i lower it i know i need a panhard bar is there anything else i need? thanx for the info
Old 04-19-2012, 07:58 PM
karpesh29's Avatar
They will fit just fine. If you lower it your going to need an adjustable panhard bar and lower control arm reolcation brackets as well. The front should be just fine as is. You might have to do some BFHing on your rear fender wells and possibly roll the fender lips but thats the extent of modifications youll need to do to fit an 18x9.5.
Old 04-19-2012, 08:16 PM
Captain Double Post
BOBS99SS's Avatar
Karp has posted the correct info, and imo i would go 18x10.5 on all 4 corners, they look a hell of alot better than the just 18x9s all around,check the post your c5dd thread and you will see what im talking about
Old 04-19-2012, 08:31 PM
do i roll the fenders on all 4 corner or just the rear?
and to bobs99ss- wouldnt they rub up front when i turn if i went with 10.5 and if so how do u fix it, spacers or what? thanx for the help so far!
Old 04-22-2012, 03:43 AM
karpesh29's Avatar
Just the rears, fronts can not be rolled as they are plastic
Old 04-22-2012, 07:57 PM
kool and the rims im lookin at r 18x9.5 with an offset of 58 and the back spacing is 7.53 if that matters. will i need a spacer for the front or what will i need to make it fit?
Quick Reply: PLEASE HELP!! will c5 deep dish 18x9.5 corvette rims fit my 2001 camaro?
