can I run bias tires tubless? - LS1TECH
Thread Tools Search this Thread
Old 04-27-2012, 11:26 AM   #1
flintwrench69's Avatar
Default can I run bias tires tubless?
I am either gonna get some ET streets or Hoosier QTPs on 15s or the 16 inch wheels I have. I found they make a tubeless bias for 17 inch wheels but is anyone running these tubeless on 15s or 16s? Thanks.
flintwrench69 is offline   Reply With Quote
Old 04-27-2012, 11:52 AM   #2
RAMPANT's Avatar
I tried to run QTPs tubeless and would lose a fair bit of air. I put in tubes and they were perfect, but heavy.
RAMPANT is offline   Reply With Quote
Old 04-27-2012, 12:49 PM   #3
jmm98LS1's Avatar
I've never run tubes. Too much rotating weight, and to be safe you really should screw the rims with tubes. My 28x12.50x15 et streets don't leak more than a pound a month when sitting, and I didn't even soap the insides.
jmm98LS1 is offline   Reply With Quote
Old 04-27-2012, 01:25 PM   #4
RAMPANT's Avatar
Quote:
Agreed on the screwing to the bead. I did.
Old 04-27-2012, 03:58 PM   #5
Thanks for the info.
Old 04-27-2012, 04:23 PM   #6
BrianSF-GA's Avatar
Here is a trick ... coat the inside of the tire with dish detergent ... use a paint brush and don't miss a spot 24+ hours before mounting. When they are mounted, have the mounter use the same dish detergent to mount them instead of their "lube".
My QTP's have not lost a pound since they were mounted the first of March. I am currently running them without screws, but have only made eleven runs with no rotation on the rim. They are marked and I am watching them closely.
Whatever you do, do NOT run tubes without screwing the rims .... if the tire and tube rotate around the rim it could shear off your valve stem ... BIG problem at 120+ MPH ... !
BrianSF-GA is offline   Reply With Quote
Old 04-28-2012, 01:16 AM   #7
Camaro396's Avatar
No tubes here in my ET Streets, or Hoosier QTP's.
Camaro396 is offline   Reply With Quote
Old 05-16-2012, 04:17 PM   #8
BSAWS6's Avatar
Any other advice for not using the screws. Somebody on another thread stated use permatex high tack sealer. Anyone else tried this. Without tubes that is
BSAWS6 is offline   Reply With Quote
Old 05-17-2012, 09:30 PM   #9
gator's 99TA's Avatar
9 second car here. Never screwed rims, never used tubes and never used any sealers. I always saw it as a complication. Heavy car too. They lose air, but so what. Its not like I daily drive on slicks.
28x10.5
gator's 99TA is offline   Reply With Quote
Old 05-17-2012, 09:32 PM   #10
senicalj4579's Avatar
I ran the et street one a few times tubeless. They were a little squirly though. I like drs.
senicalj4579 is offline   Reply With Quote
Old 05-18-2012, 10:13 AM   #11
Grn4fbody's Avatar
My ET Street's didn't have tube, it would lose air fast though
*Edit* like 5LBS a night
Grn4fbody is offline   Reply With Quote
Old 05-18-2012, 10:42 AM   #12
1badSS's Avatar
I soaped my E/T streets on the inside as well it work great.
1badSS is offline   Reply With Quote
Old 05-18-2012, 11:26 AM   #13
BrianSF-GA's Avatar
Quote:
I doubted this at first, but now a I am a believer ... it's now May, still no loss. Currently down to 15# and have about 17 passes on them and they have sat in the garage when not at the track.
Old 05-18-2012, 11:41 AM   #14
BrianSF-GA's Avatar
As an update, my QTP's rotated 1/2" after six 1/4-mile passes at my last trip to the track.
Soooo ... after eleven 1/8-mile passes trapping 103 mph and 1.7x 60's without a line lock or 2-Step, there was no rotation on the rim at all compared to a 1/2" of rotation after six 1/4-mile passes trapping 122 mph and 1.6x 60's with a line lock and a 2-Step launching at 4,000 rpm.
The difference in rotation could be the trap speed (103 vs. 122), the better launch from an improved burnout, higher rpm and rear DA's (hence a .10 second quicker 60's) or a drop in tire pressure from 18# to 15# .... I am thinking all of these factors. As I bring down my 60's, the rotation may increase forcing me to screw the rims.
Old 05-18-2012, 08:08 PM   #15
blackls1ta00's Avatar
screw it you will feel much better!!
blackls1ta00 is offline   Reply With Quote
Tags
air, beads, bias, et, leaks, lose, mount, mt, running, street, streets, tire, tires, tube, tubeless
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
