Preferred way to add spacers?
Old 05-01-2012, 03:31 PM
02TransAm/Batmobile's Avatar
Default Preferred way to add spacers?
I am a bit confused with all this terminology. What is the difference between hub centric and wheel centric and which is preferred? I am not talking about adapters but the single spacer itself.
Right now I have upgraded to longer ARP studs and running a cheapo 3/16" Doorman spacer for clearance issues. I want to run a thicker spacer for aesthetics but concerned about safety.
Old 05-01-2012, 03:59 PM
LS1Tech Platinum Sponsor
rudytirerack's Avatar
A hub centric spacer which is preffered has a pilot that comes out to make the wheel hub centric which helps to prevent vibrations. I recommend getting a good quality spacer like the H & R brand.
See this thread: https://ls1tech.com/forums/wheels-ti...ers-added.html
If you look at the smaller round opening and see the pilot extruding out. That should be hub centric.
