Skinnies too big
Old 05-10-2012, 08:38 AM
TXCatfish's Avatar
Default Skinnies too big
Not sure of the offset size but the tire size is 26x6-15. Looking at it from the side it looks like maybe the tire is too fat.
Should I run a 26x7.5-15? And is it possible the offset is wrong or is there only one offset size that will fit on here?
Thanks!
Old 05-10-2012, 08:49 AM
Stippy17's Avatar
Looks fine to me??
Btw a 26x7.5x15 will be even wider than what you have now..
Old 05-10-2012, 08:56 AM
TXCatfish's Avatar
Originally Posted by Stippy17
Looks fine to me??
Stip that's what I thought but could have swore I saw on a size calculator it was a little more narrower.
I know I've seen other racestars that look like they are more tucketed in then sticking out like mine.
Old 05-10-2012, 09:22 AM
J-Train's Avatar
7.5" is the width vs 6" you have now. And those tires are a serious waste of cash for what you get. You should have went with a 165/80/15 radial.
Old 05-10-2012, 10:32 AM
TXCatfish's Avatar
These came with the wheels. So are the 165/80/15 narrower and shorter or just narrower? Just curious what's wrong with m/t sportsmans?
Old 05-10-2012, 02:37 PM
fitz98ta's Avatar
you need a 26x7.5 15 in the sportsman PRO tire, if you want to change to a 7.5. It is a bias ply, but it's the actual tread width that is measured, not the width of the tire (Actual tread goes into the sidewall). That's the tire I ran (see sig pic)
I personally wouldn't run the 165 VW tires, our cars are way to heavy for them. I have ran them and millions of others run them without problems, but I wouldn't do it again.
are you running a spacer? to me it almost looks like the wheel sticks out too far. or maybe the offset is wrong. FWIW The tire looks about right on the wheel (doesn't bulge too much)
Old 05-10-2012, 03:25 PM
TXCatfish's Avatar
No spacers, but I do use these black plastic rings I guess so the wheel can fit snug on the rotors. I had the wheels off yesterday and didn't even think about looking for the offset size or measure them.
Fitz I am running M/T sportsmans right now, not sure if they are the pro's.
So I guess I need to measure for offset size 1st, if they are 1.75bs I have correct rims and wrong tires?
Old 05-10-2012, 03:33 PM
Stippy17's Avatar
If you have 1.75 BS wheels they are correct. And your running the correct tires. Just make sure if you have bias rears you run bias fronts, and if you have radial rears you run radial fronts.
I run VW 165/80/15 front tires with no problems. Overinflated them to 35-40psi for the track, and normal psi for the little street driving I do to/from the track.
Old 05-10-2012, 03:51 PM
TXCatfish's Avatar
Okay may wait till the weekend to measure.
Thanks!
Old 05-11-2012, 10:13 AM
studderin's Avatar
how do thous tires drive? Im thinking about getting them over mt Nexes sheap skinnies I have now, there only 25 tall
Old 05-12-2012, 10:43 AM
TXCatfish's Avatar
They seem fine to me. I may only drive on the streets on the weekends and sometimes drive to the track with them. I did drive back from the track last night during a tornado warning, flood warning, severe thunderstorm warning, and might have been a tsunami warning and made it home with no issues.
Quick Reply: Skinnies too big
