C6 vette rims wont fit my 99 z28!
Old 06-09-2012, 07:36 PM
RollingThunder99's Avatar
Default C6 vette rims wont fit my 99 z28!
A friend of mine was going to sell me his stock c6 corvette rims. When I tried to test fit them the were about an inch too wide. Is there any way I can make them fit? Or are there other options? Please help me out thank you!
Old 06-10-2012, 05:50 AM
LS1HIGHLIFE's Avatar
Run a spacer if they rub the inner fender well, or BFH the **** out of them.
Old 06-10-2012, 08:53 AM
SweeTbone's Avatar
You need to run a 1.25" spacer on the back to get them to fit. Fronts should bolt up fine.
Old 06-11-2012, 05:31 PM
Will the studs be long enough with the spacer tho?
Old 06-11-2012, 05:40 PM
babbage1109's Avatar
Anytime you run that size of adapter You need longer studs. Unless you get the adapter with the studs built in
