AM I CRAZY? Wheel and Tire help!!!
Okay I want to run 19"s mesh wheels (MRR GT1s) (RPM 505s)
Now I know the wheels fit with hubcentric rings thats not my problem
Every time I look for a wheel and tire packages. The tires are always a 35 aspect ratio in the front and 30 in the rear..and that seems rather thin for a sidewall...Am I crazy to want to run a 245/40/19 Front and 275/35/19 Rear on 19X8.5 Front and 19X9.5 Rear?
I'll probably go with MRR GT1s on my 98 Red Camaro Z28
Thanks.
Also I used 1010tires.com tire calculator to find tires that are within the 3% tolerance of size that doesn't risk brake failure and they are really close to same speed front and rear... for example I think the 275/35/19s are only .526% faster than the 245/40/19 so at 60mph you're really going 60.3mph. Also the sidewalls are very similar in thickness. Fronts are 3.85" and Rears 3.78"
Thanks.
I know its not the height in mms. Hmm I guess a 245/35/19 and 275/30/19 don't have a sidewall much thinner than the 245/40/19s and 275/35/19s.
245/35/19 sidewall height - 3.37inches
245/40/19 sidewall height - 3.87inches
275/30/19 sidewall height - 3.24inches
275/35/19 sidewall height - 3.78inches
What I'm saying is that I'll lose about a half inch on the sidewall height.
I guess I'm really asking if I'll have rubbing problems with 245/40/19 and 275/35/19?
Also the a 245 tire fits 8-9.5 wheel.
Thanks for the help.
I guess I'll go with 245/35/19 and 275/30/19 since that's what you guys recommend and the tire packages. I'm trying to keep this package on the cheap side so my tire choices are
Achilles ATR Sports -$1,694
Nexen N3000- $1,906
Falken Fk-452- $2,032
Nitto NT555- $2,128
Michelin PS2- $2,852
I can also order the wheels and tires separately. this is from wheelstudio.com
I want the best combination of handling and wear.
Nexen N3000- $1,906
Nitto NT555- $2,128
Nexen N3000- $1,906
Nitto NT555- $2,128
Nexen N3000- $1,906
Nitto NT555- $2,128
Thank you everyone for your input.
I've decided to go with American Racing Torq Thrust Black with Machined Lip
17X9 Fronts
17X10.5 Rears
BFGOODRICH G-Force KDW2 275/40/17 all the way around.
It looks good with my Red Z and it's a decent price $1,424 mounted and balanced before shipping from tirerack.com
17X9 Fronts
17X10.5 Rears
17X9 Fronts
17X10.5 Rears
17X9 Fronts
17X10.5 Rears
New possibility
2009 ZR1 gloss black replicas
18X9.5 +40mm front
18X9.5 +56mm Rear
with BFGoodrich G-force KDW2 275/40/18s all the way around?
about $1,694 before shipping balancing and mounting?
18X9.5 +40mm front
18X9.5 +56mm Rear
First off, pick a wheel and stick with it. Secondly Ive never understood why people bash Asian tires, but its your choice so do as you please. With a 9.5 I would do 285/35/18s
