Snapped 10 arp wheel studs
Old 07-10-2012, 01:21 PM
Mgill's Avatar
Default Snapped 10 arp wheel studs
Snapped 10 arp studs when taking off my drag wheels. Had no issue removing the stock lugs and wheels at the track. When I removed my prostars yesterday I snapped 8 studs and striped the other two, I cant get two lugs out of the wheels, and the lug nuts are bulging in the centers. WTF I have the worst luck with wheel studs! Anyone else have issues? Arp says Im SOL because i used the lugnut method to press them into the hub since I dont ahve access to a press.....anyone else have issues with the shank style lug?
Old 07-10-2012, 01:52 PM
GA95DCMSS's Avatar
Did your lug nuts come with a spacer/washer? If they did, did you use it when you installed the wheels? I personally haven't had a problem with the shank style lug nuts on my bogarts after about 4 years of use.
BTW, pulling them in with the lug nut is a horrible idea IMO. Use the proper tool to install it and save yourself the trouble down the road.
Old 07-10-2012, 01:59 PM
Mgill's Avatar
I do it all the time with stock studs and enver had an issue, yes I used the washers.
Old 07-10-2012, 03:31 PM
GA95DCMSS's Avatar
When you used the "lugnut method" to install the studs, did you use the stock set or the shank style?
Old 07-10-2012, 03:58 PM
Mgill's Avatar
I used a stock one and a big bolt to space/center it.
Old 07-10-2012, 04:35 PM
therobman's Avatar
^ thats way i installed mine i dont have any issues
Old 07-16-2012, 02:06 PM
98BLOWNZ28's Avatar
i actually broke an arp stud as well. trying to remove it.
i installed them with a lug nut, and a breaker bar. no problems whatsoever.
i wouldnt recommend using an impact to install, i could tell you that much.
Old 07-16-2012, 05:19 PM
Camaro396's Avatar
Greg Weld/Racestar wheels?
Old 07-16-2012, 08:34 PM
SLP IROC-Z's Avatar
over torqued and yielded them
Old 07-17-2012, 11:37 AM
FASTS454's Avatar
Or bottomed out the lugnut on the stud.
Old 07-17-2012, 11:47 AM
ec_nova's Avatar
buy a stud installer next time. They're $40 from matco and with a little antisieze they make installing the studs very easy. But it sounds like you either have the wrong lug nuts or your overtorqued. What are you torquing them to? I've never seen this type issue with ARP studs before. Also did you use center rings? It's possible the wheel wasn't center if you have uni-lug and it beat the **** out of the studs
Old 07-17-2012, 12:19 PM
SLP IROC-Z's Avatar
post a picture of the broken studs, it will be easy to tell from the fractures why they broke.
Old 07-18-2012, 08:40 AM
69TA's Avatar
did you pull the studs thru with the lug nuts when you installed
them on the axles or did you remove the axles and get them pressed thru?
maybe you over stressed them when you installed them on the axles.
Old 07-21-2012, 02:48 AM
meine96ws6's Avatar
I tried to pull them through 1 time... broke a stud, stripped the second.. lets just say pressing works wayyy better big guy.
Quick Reply: Snapped 10 arp wheel studs
