Help Installing Wheels Tomorrow Need Lug help
Installing Dark Stars Tomorrow 15x10 7.5 BS 28x11.50x15 Fronts are 15x3.75
I have moser 12 bolt and have 1 3/4 Moser Studs they are threaded all the way. Will these be long enough and safe?
The stock lug turns 15 times around with about a 1/4 inch of nut that isnt being used 3/4s of the nut is threaded on the stud. This is with just the rotor no wheel.
I checked today and I can fit 2 1/4 stud withought pulling the axle.
Now for the tires Do the bump stops have to come off?
Calipers Grinded?
Fender Rolled?
Now what about the front I havent checked but im assuming stock studs etc
With the Race Stars there is no front spacer required?
Any grinding of calipers?
If there is no spacer required can I run the stock lugs?
Can these be balanced with weights inside?
Calipers Grinded?
Fender Rolled?
