Will my car sit higher after larger wheels?
It stands to reason that larger wheels would set the car up a little, I just want to check and see what you guys think.
I'm asking because I want to see if lowering my car can finally be an option after larger wheels (because of my street sweeper exhaust setup). I'm looking to put 17's in the front and 18's in the back and I want to see how much this will lift my car?
Go to the tire manufacturers website and look at the specs of the tires you are looking at, they pretty much all have it listed, though it's harder to find on some. I couldn't find Bridgstones info, so I looked up the specs of the their tires on tirerack.com. It does change the way the car sits if your new set up has different overall dimensions than what you have now, which they most likely will.
I know my current wheels (~26" diameter) are around .5" larger in overall diameter than what I have on the stock wheels (~25.5" diameter). that's a quarter inch per side of the wheel, which means a 1/4" further off the ground, and a 1/4" more space filled between the wheel and the fender, which actually gives the appearance of the car being lower.
checking the measurements also helps with checking to see how your front wheels will sit compared to the rear when doing different sizes. I almost went with tires that would have had the front tires larger than the rear, which would have looked stupid.
A 295/35/18 tire is right around 26", a 295/30/18 is right at 25". That 30 series was a bit too thin for me.
It kinda depends. For me, my car sits higher now with the current wheel/tire combo than the stock 17 inch combo. I haven't scraped my headers or y-pipe at all since going bigger.
I have Hooker longtubes and 3" exhaust piping, no disgusting wheel gap, PLUS I have a decent amount of ground clearance with my wheel and tire combo.
What kind of exhaust setup do you have? IMO, the primary objective is to reduce unsightly wheel to fender gap. Then choose a wheel and tire combo that will give you the additional ground clearance you may need if you have scraping issues.
