1996 Z28- Will pulling ABS Fuse cure ABS light?
Hey, Just reading and searching on the forums, but I could not find a direct answer.
I would like to put a taller tire (27.76) and I know it may/will casue the ABS light to come on. (Not sure about a 96?)
At any rate, would pulling any fuses that would disable the system turn the light off the dash??
Thanks!
Thanks!
You will need to pull the ABS fuse when running a taller tire in the rear. If you don't the ABS will activate when braking hard. Pulling the fuse causes the ABS light on the dash to stay on.
