19X9.5 with +30 offset fit?
Old 11-06-2012, 02:46 PM
keit29's Avatar
Default 19X9.5 with +30 offset fit?
Car is an 01 trans am lowered 1 inch all around. Anyone running that low of an offset? I'm mostly worried about the front as my rear fenders are already rolled and should clear fine. Thinking a 295 rear and maybe 275 front if it will fit.
Old 11-06-2012, 04:54 PM
TORK?'s Avatar
Its basically a 19x9.5 with with 6" backspacing. Should be fine on the rear.
Can't speak definitively for the front. You'll be fine backspacing wise, but the 3.5" on the outside may come very close.
Old 11-07-2012, 01:20 PM
Skraight's Avatar
I ran that same offset in the front of my camaro. You can check my threads to see it.
I ran a 10.5 +30 on the back with a 275 and 9.5 +30 front with a 245
Old 11-07-2012, 01:25 PM
keit29's Avatar
Checking now...
Quick Reply: 19X9.5 with +30 offset fit?
