will the bremmer rims fit my 1999 Camaro?
Old 11-08-2012, 09:36 PM
fivepointseven's Avatar
Default will the bremmer rims fit my 1999 Camaro?
https://ls1tech.com/forums/pontiac-g...m-lugnuts.html
any insight? thanks
Old 11-08-2012, 10:00 PM
__Z__'s Avatar
Will they fit? Sure, 5x150 will work on camaro's, however you may wanna check the offsets to see how they will look
Old 11-08-2012, 10:25 PM
SS SLP2's Avatar
not sure, I seem to remember reading that there is small differance in the bolt pattern with that wheel and the OE WHEEL- will fit but may work loose
just my .02' Johnny
Old 11-09-2012, 02:13 PM
VinR1's Avatar
They'll fit, you wont be happy with the way they sit though - see below
These are wider with a lower offset. Those will tuck in a half inch more. If you do get them, you'll want at least a 1" hubcentric spacer/adapter all around
Old 11-10-2012, 09:09 AM
+45mm is the offset. Thanks for the info!
Old 11-10-2012, 09:18 AM
babbage1109's Avatar
Just get a spacer to make it a +37/38 offset and you'll be fine.
Old 11-10-2012, 01:55 PM
VinR1's Avatar
38mm offset is fine for a 9.5" or 10" wheel. A 8" wide wheel needs an offset of 15-20mm to look halfway decent on these cars
Old 11-10-2012, 04:09 PM
That's true. I forgot with my wheels they are 9.5/10.5 so the offset is different
Old 11-10-2012, 07:24 PM
__Z__'s Avatar
Just get 5x4.75 to 5x120 1" wheel adapters and call it a day, solves all your problems.
Quick Reply: will the bremmer rims fit my 1999 Camaro?
