What front tire with Toyo Proxes TQ?
Old 11-29-2012, 11:05 PM
Super Hulk Smash
JakeFusion's Avatar
Default What front tire with Toyo Proxes TQ?
Looks like the Proxes TQ are my best bet for rear tires. But what tires are folks going with in the front to match it pretty well? I thought about doing the RA1s since they are a DOT competition tire as well. I don't want the tires to be too different for braking/handling.
This would be for a 275/315 setup.
Originally, I had thought NT05 and NT05R, but it seems like the TQ are a bit better for the street. NT05 might still be the way to go on the front.
Also, Toyo has an R1R tire that looks crazy, but it's a street tire. Probably the same as NT05 rubber.
Old 11-29-2012, 11:20 PM
HCI2000SS's Avatar
You won't regret the TQ's I had those on my Mustang and they wore like a Nitto 555R, but stuck much better!
Old 11-29-2012, 11:58 PM
Super Hulk Smash
JakeFusion's Avatar
Cool. That'll be helpful lol
Old 11-30-2012, 10:48 AM
Beave's Avatar
maybe a toyo r888 up front?
Old 11-30-2012, 12:40 PM
Super Hulk Smash
JakeFusion's Avatar
Aren't the RA1s even better? Back in 09 SCCA had to switch back to the RA1 cuz people bitched about the R888s...
Oh well.
Old 11-30-2012, 01:40 PM
Beave's Avatar
Not sure, i dont do any road racing or auto x. Just know ppl that had good results on the r888
Old 12-06-2012, 01:51 PM
SSCamaro99_3's Avatar
I think you are way overthinking this. Tons of people run a street tire on the front with a drag radial in the rear. I ran Firehawk Wide Ovals with my NT-555R's. There were no ill effects. I never felt like the rears were out powering the fronts from a handling/braking perspective. If anything, the softer sidewall in the drag radial negates some of the lateral grip of the tread compound as the tire rolls over quicker.
Old 12-06-2012, 02:24 PM
Kingc8r's Avatar
I have some generic 245s on front paired with my Toyo TQ 315s.
I also agree that they stick better than 555rs and wear just as we'll if not better. They were even ok in the rain ( I drove carefully )
I'm cammed & stalled and I rarely spin on the street
Old 12-06-2012, 04:15 PM
fly boy_1's Avatar
I'm running the regular NT05's in front with tq 315's in back. When I replace my front tires, I think I might try something that wear a little slower. My nt05's wore out the center very fast at street psi, I had to drop them down to about 20-25 pounds of air.
In terms of braking/handling, as I mentioned in your other thread a drag radial isnt ideal. I felt a big difference going from the 275 nt05s and the 315 toyo's. With the DR's you will feel the rear end tend to wallow around a bit under steering input whereas the nt05's felt much more stiff and responsive. It does seem to track a **** ton better just going straight though. Less tendency to follow cracks in the road compared to the 275's they replaced.
If this is gonna be for street driving you'll get used to it, but the limits are noticeably lower in cornering with the toyo's so if you want to be competitive I'd get a hardcore/autox road race tire for the rear. I'm sure some of that is due to going from 275's on all corners to the 315s and not adjusting the rear swaybar or something, but its good enough for me.
For street driving I'm pretty happy with the nt05 and toyo tq combo. It's not like you're trying to push 1g laterally in a DD situation anyway. Since your car is an A4 I'd bet your car would probably hook a bit better than mine with those tires at the track too.
Quick Reply: What front tire with Toyo Proxes TQ?
