Wide 11 or 12 inch wheels on the back? lol
Old 12-03-2012, 10:52 AM
Blackpanther99's Avatar
Default Wide 11 or 12 inch wheels on the back? lol
Hey there guys, I have a quick question for you, I have seen a couple of T/A and Camaros running 11 inch wide wheels on the back, in order to install that size of wheel I would have to hammer or at least modify my fender right? not for drag slicks tires but with street radials
Have some of guys even seen or read about putting some 12 inch wide wheels on the back? I apologize for the dumb questions but im just curious to know if that such wide wheel could fit and if it would need a spacer to make them fit on any T/A
Old 12-03-2012, 11:16 AM
VinR1's Avatar
Lots of people put 11" wide wheels with 315 width tires on the rears with some work - rolling the fender lips and some, if any, hammering to the inner fender. The offset of the wheel is what's most important - 45-50mm is preferred
search for putting the 12" Corvette wheels in the rear - some have had no issues, some couldnt make them fit
Old 12-03-2012, 11:21 AM
Thanks for the quick response! Ive been wondering because I want to put some 18x11 or 12 on the rear and 17x9 in the front on my T/A Ive always liked that back wide wheel look on F-Bodies
Old 12-03-2012, 11:24 AM
VinR1's Avatar
stick with 11" in the rear - more tire choices and less work to make them fit
Old 12-03-2012, 11:41 AM
Ive seen your car on the thread about which tips are better on a WS6! lol I read that you have the corsa clones, your car is sick!
Old 12-03-2012, 11:57 AM
southpaw0314's Avatar
I have 12 inch rims on my camaro. it took a lot of work to get them to fit without rubbing, a lot of test fitting.
Old 12-03-2012, 12:01 PM
Man that must suck, what did you exactly do to make them fit on there?
Old 12-03-2012, 12:06 PM
Sail Hatan's Avatar
i have had 315s and 11 inch rims on all of my F bodies. my last camaro for a little better than my current t/a, but the T/a is running them with 0 modifications. just bolted on.
Old 12-03-2012, 12:27 PM
sscamaroburn02's Avatar
i have 315 nittos on 11 wide wheel. No mods necessary just bolted on and off I went. No rubbing to date. I do have PHB to center the rear so maybe that helped.
Old 12-03-2012, 02:44 PM
Looks like ill be looking forward to some 11 wide wheels save me from problems lol and which diameter are you guys running those 11s with?
Old 12-03-2012, 03:56 PM
Sail Hatan's Avatar
I run a 17x11 zr1 from oewheels
Old 12-03-2012, 04:03 PM
Oh ok, you think 18s will work with no problems?
Old 12-03-2012, 06:05 PM
LPE 403's Avatar
No probem....18 x 11 315/30
Old 12-03-2012, 06:19 PM
Captain Double Post
BOBS99SS's Avatar
Make the choice on what size wheels ya want,its not much work to fit 18x10.5s,11, mainly its going to depend on your suspension set up,315s on 17x11s is for sure the way to go but that leaves ya with tt2s or zr1s,
Old 12-03-2012, 06:27 PM
Car looks sick bro! I love that rear view to whete you can see the wheel pass out of the car's fender lol
Old 12-03-2012, 06:28 PM
Yeah I have in mind some Boyd Coddingtons or the TT2s
Old 12-03-2012, 06:36 PM
it also depends on what brand tire you run to, nittos run narrower then other tires.
Old 12-03-2012, 06:37 PM
we had to roll the fenders, hammer certain spots in the wheel well and cut the bump stops in half.
Old 12-03-2012, 06:39 PM
Blackbird-WS6's Avatar
im lowered with 11inch rims and 315 tires and have no mods done to make them fit
Old 12-03-2012, 06:48 PM
ls1dames's Avatar
I am running the 17X11 AR Torq Thrust M wheels out back and they don't rub one bit. Even with the car lowered 1" it hasn't been a problem. I tried running an 18 inch C5 Corvette wheel at one time and it rubbed every time i went over a bump. I don't know the exact specs on any of these wheels, sorry.
I think the issue is with 18" on up. With the larger diameter you will have some rubbing issues if your car is lowered and you want to go that deep of a wheel. I even tried fitting a 19" C6 wheel but had to add a wheel adapter to make it fit without rubbing. Happy motoring my friend!
Quick Reply: Wide 11 or 12 inch wheels on the back? lol
