Different wheel/tire sizes turns off the ASR/ABS
Old 12-12-2012, 05:57 PM
American-Muscle1989's Avatar
Default Different wheel/tire sizes turns off the ASR/ABS
Hi all,
Had the car for about 3 weeks now. When I bought it the owner told me that because he had 245/40/17s on the front and 275/40/18s on the rears both from a Corvette on the car and once the car goes over 50mph (roughly) for a while it turns off the ASR and anti lock brakes because it can sense a difference between the front axle and rear axle.
Under about 50mph it does not turn them off so I believe it is true.
I will be picking up a set (x4) of 245/40/18s soon and I wondered if I fitted them so they were all the same would that stop the ASR and ABS from deactivating?
Thanks guys
Alex
Any thoughts guys? I am going to try out my plan tomorrow to see if that stops the lights coming on
Old 12-16-2012, 04:17 PM
OK fitted the 18s and it is true, different size wheels will set off the asr and abs so now that I have all the wheels the same the abs and asr stay on and the lights don't come on.
Thanks
Old 12-16-2012, 04:39 PM
Kurt D's Avatar
You can make staggered wheels work, the total diameter must be within a 1/4-1/2 inch. I'm running 265/40zr17 front and 295/35zr18 rear and never had a problem with the computer (ran 275/40zr17 front and 295/35zr18 rear previously, also with out issue).
Old 12-19-2012, 09:07 AM
Marc 85Z28's Avatar
Back when I had 245/40r18 front and 285/35r18 rear the ABS/TCS did not disable itself. HOWEVER, on hard braking from higher speeds (end of 1/4 mile especially) the ABS would activate when not necessary creating some very scary instances - the car would almost refuse to stop. You may have the same problem with the 275/40r18 in the rear.
Quick Reply: Different wheel/tire sizes turns off the ASR/ABS
